Hello, I have an EasySolarII GX and problem with wait message being displayed. Wifi of GX stopped working and Remote LAN console was not enabled on the GX hence I can't connect with ethernet. How can I possibly connect to GX to fix this issue?
Try some of these:
Power down EasySolarII for 2 mins and restart try connecting via WiFi again.
Try using a different device to connect to WiFi. If you see WiFi use the 172.24.24.1 to get back in.
Is it connected to VRM? If so use the remote console via VRM to get back in.
Once back in always enable LAN and have VRM connected which always gives you 2 ways to see and change the GX.
44 People are following this question.
