eliott avatar image
eliott asked
LFP Smart battery with Quattro not going into "absorption" every 7 days
Hi!
I have a 48v install with s2p2 24v smart LFP battery with a Quattro connected to it. I have almost 3000 data points in VRM and see that the voltage never goes above 54.5. With other installs I see that the voltage goes to absorption where the cells are equalised by the BMS.
Also, maybe it is unrelated but I can't seem to connect to the remote console, although I am almost certain that I have enabled the feature.
Any suggestions?
MultiPlus Quattro Inverter ChargerLithium Battery
eliott avatar image
eliott answered ·
By the way the Quattro is programmed with the standard settings
eliott avatar image
eliott answered ·
Hi!
I still couldn't find a solution or a reason. Pinging @Victron
eliott avatar image
eliott answered ·
I bump this to the top, maybe someone can suggest. The first question is if it is a problem or not and I souldn't worry
