clasence avatar image
clasence asked
Change Generator start/stop SOC rules with mqtt
I have turned on MQTT on my CCGX and I am able to subscribe and get messages. I want to be able to change the generator start/stop rules which are based on the Battery state of charge. They are current at 50% and 70% but I want to be changing them programmatically depending on forecasts. Does anyone know the topic to publish to so these values could be changed?
GeneratorSOCMQTT
clasence answered ·
All the paths are actually found on the dbus_generator source code here. In my specific case, I wrote to the following paths:
Genset SOC stop value (upper threshold)
"W/{portal_id}/settings/0/Settings/Generator0/Soc/StopValue" with payload {"value": 71.0}
This sets the upper threshold to 71% and the generator stops running when SOC is 71%
Genset SOC start value (lower threshold)
"W/{portal_id}/settings/0/Settings/Generator0/Soc/StartValue" with payload {"value": 50.0}
This sets the lower threshold to 50% and the generator stops running with SOC is 50.0
sanderson avatar image
sanderson answered ·
@clasence, out of curiosity, are you going to adjust them based on machine-friendly forecasts or manually every once in awhile?
