If I the MultiPlus is set to charge-only with the front-panel switch, is it then possible to externally pass the input AC to the output to use only grid power, or will only cause it to vent some kind of smoke?
It is possible and recommended if you don't want to accidentally discharge the system on some loads.
it will pass the power through, in the charger only position, up to maximum of the transfer ability of the unit and your wiring of course.
No "pass-through" in charger only mode.
92 People are following this question.
How can Multiplus 1 be used to increase charge power in ESS system with Multiplus 2 and GX
>10kVA and dedicated production meter
Camper Van Schematic - please critique
Are my MultiPlus II VE Config charger settings correct for 4 x Omnipower 200Ah batteries?
firmware compatibility three phase system MultiGrid-II and MultiPlus-II
