The multi appears to be working in all other respects any ideas would be welcomed.
Regards RoyLR
Regards RoyLR
We would probably need more info here.
But first check - is the battery ok? Above the cut off voltage?
Second can be daft - switch position?
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
40 People are following this question.
