ian77 avatar image
ian77 asked
MPPT 100/20. Сyclic mode AES (Load output)
I use SmartSolar MPPT 100/20. When you turn on the AES (Automatic Energy Selector) mode (Load output), the output to the load turns on after 2 minutes, as it should, works out the set time and turns off. But after 2 minutes, the cycle repeats again. And so on until the battery voltage goes beyond the set limits. How do I make the cycle repeat only once?
fault
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
