pwfarnell avatar image
pwfarnell asked
Victron - update the Cerbo GX manual for WS500 current and temp sharing
Now that V2.5.1 firmware is available for the WS500 which can read battery current and temperature from the Cerbo GX (assume any GX device with Venus OS) for non BMS systems does the WS500 section of the Cerbo GX manual need updating to clarify what shunts will work and if anything needs setting up. Does it automatically send the main battery current and the temperature you have set for the battery on DVCC STS.
I believe the Cerbo code was added in early 2023 in Venus V2.93 but it has taken a while for Dragonfly Energy to update the WS500.
See manual section below
https://www.victronenergy.com/media/pg/Cerbo_GX/en/connecting-supported-non-victron-products.html#UUID-6a1f69a8-543b-c0b6-b30f-9fc4e70ad24d
cerbo gxws500
