Good day,
Is there any issue by setting up several units of Quattros in three phase for an ESS system but with AC input from a single phase configuration?
This is because is intended to run three phase motors.
Regards.
Good day,
Regards.
This can be done by turning off switch as group when setting up the system, and connecting the grid to only one of the Quattros. The AC inputs of the other two Quattros would not be connected to anything.
The unit connected to the grid will pass through power to loads on that phase when grid is present. The other two units will always run in inverting mode, powering the loads on those phases from the battery bank.
Be advised that only the Quattro connected to the grid will charge the battery bank.
If needed you could supplement battery charging from the grid with an AC charger such as Skyla, etc.
@Alexandra :(. Isn't there any way to configure the system as selfconsumption?
You would either have to clever it with node red, or use AC ignore.N ot something I have looked into with a bigger system such as yours.
A much simpler way to charge from a single phase would be to use inverters/chargers specifically for that, as the generator does not support the three phase loads anyway. (So yes more units)
Then you can ESS of grid as normal.
Thank you @Kevin Windrem for your response. In my case there will be 9 units of 10kW considered for the design as shown:
In that case only three inverters will have the input connected and six will run as inverter?
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
Parallel, split- and three phase VE.Bus systems manual
Theory on wiring large systems PDF
Three-phase and parallel system theory training presentation
80 People are following this question.
