4senergy avatar image
4senergy asked
In which port in the Cerbo GX should I connect SMA sunny boy Ethernet cable ?
I have 4 Quattro configured in parallel (split phase 240 V), and 3 sunny boys SB7.7.
—> PVsuport assistant is set for frequency shifting.
—> sunny boys are set to Island mode 60, for responding to frequency shifting of Quattros.
I want to see the sunny boys power production in the GX touch screen. Which port of the Cerbo GX should I use? Should I use the Ethernet port of the Cerbo by connecting it via an Ethernet cable to a router, and the sunny boys also to the same router?
AC PV Couplingmonitoring
They have to be in the same LAN.
https://www.victronenergy.com/live/ccgx:ccgx_sma
4senergy answered ·
Thank you Matthias!
