dubzy777 avatar image
dubzy777 asked
Can you run PV inveter assistant with self consumption hub 2-v3?
Just wondering if you run PV inveter assistant with self consumption hub 2-v3. the system is a stand alone system with generator back up ?
AC PV Coupling
boekel avatar image
boekel answered ·
Ah...off grid :)
just use the PV-assistant and the generator assistant.
ESS / Hub is for grid connected systems
if possible I'd connect at least part of the solar to the DC-side with Victron MPPT controllers less conversion losses (but might not be practical due to other reasons?)
boekel avatar image
boekel answered ·
You'll have to give more info to get answers (diagram of the system, etc.).
Why would you want to use hub assistant?
dubzy777 avatar image dubzy777 commented ·
8.2 primo fronius
9600w PV
15000 quattro
essentially just want the PV to charge the batteries and handle day time load which is does fine and the generator to start when the SOC or battery voltage gets low?
