mpoublon avatar image
mpoublon asked
Not charging when van is running help?
Having issues on my first road trip
While driving I’m not charging my batteries. Solar is fine but nothing from charging system from van
Not sure if my outfitter setup the Orion smart hq correctly.
He had me check under config and it showed float. I reset to factory default and now I get this but still not charge when engine is on.
Any ideas?
battery charging
Please post screen shots of the Orion and MPPT battery settings. What type of battery is it? Lithium or AGM?
The Orions should be charging, but the shunt says otherwise. And has a strange voltage reading. Could be it's wired to the starter battery.
mpoublon avatar image mpoublon kevgermany ♦♦ commented ·
They are lithium and I would have expected to wire this correctly
This is a new build
mpoublon answered ·
Problem solved
Loose cable
mpoublon answered ·
