americanium avatar image
americanium asked
Pylontech US2000 settings in VE-Configure
Hello!
I have (currently) 2 Pylon US2000 in use and want get assure, that the configuration within VEConfigure is correct. So i would appreciate if you could confirm the settings.
I have had a defect US2000 about 1 year ago which was bloated with overvoltage warning in 1 cell. But all 3 packs bloated... so I'm want to get sure that the settings are 100% correct.
THANK YOU!
See picture below:
battery chargingLithium BatteryPylontech
Alexandra avatar image
Alexandra answered ·
@americanium
That all looks correct.
Do you have the Comms cable into the GX so that DVCC can also make sure the combined solar and grid charge does not exceed the battery max continuous?
americanium answered ·
There is no solar directly connected. Loading just over grid, so that should be no problem.
