kp4djt avatar image
kp4djt asked
DC Load always shows zero
Folks, I am using a SmartShunt as a load meter. I can see it in the devices, it shows the load going through it but it does not show any load in the graphic.
If I look at the devices they are certainly there here is the Remote Console view
Another view of Device list
And the expanded view for DC Load which is the SmartShunt
All appears to be working but I cannot get the SmartShunt to show the flow of power to the load.
I have set it up as a meter rather than a battery device.
Energy Meterdc meter
Kevin Windrem avatar image
Kevin Windrem answered ·
I think you need to program the shunt for DC System, not DC Load. Yes, that's a bit confusing. DC System has always calculated "other" DC loads and sources and the DC meter setting for DC System is intended to mimic that.
I suppose DC loads could be separated from DC charging sources and if only DC loads are present, the tile could be renamed, but that's for later and a low priority at that.
kp4djt avatar image
kp4djt answered ·
Thank you very much that took care of it, went right in and changed to DC system and it showed right up.
Energy Meter Selection Guide
