jestron avatar image
jestron asked
hoymiles 1200 on acOut, frequency watt reaction: mysterious peak
I have some hoymiles 1200 on ac-out. 1/1 rule is obeyed.
During off-grid/usv testing, the hoymiles ramp down resp. switch off as expected during frequency rise.
But when frequency comes back down, vrm shows a short peak load, sometimes more than 1kw. (see screenshot)
any ideas?
VRMVictronConnectMQTT
Alexandra avatar image
Alexandra answered ·
@jestron
It is probably what the AC PV takes to wake up again. Is it off off or in a low power state? I have not used a hoymile so guessing here do you hear relays in it clicking etc?
jestron avatar image jestron commented ·
Still no clue what might take 1kW after return to 50 Hz. Perhaps a phantom peak, as it appears even when no load is left connected.
dennibu avatar image dennibu jestron commented ·
Ich könnte mir vorstellen, dass beim Einschalten des NA-Schutzes die Kondensatoren des AC WR plötzlich aufgeladen werden. Ist die Spitze oben glatt, wenn Sie in das Bild hineinzoomen?
jestron answered ·
Thanks for the hint, there are some more loads (refrigerator, fans, pumps) on acOut. Will try to drop them one by one :-] and watch the result on frequency change.
