adamszabo avatar image
adamszabo asked
Venus GX D-bus round trip time too high
I have a problem with a Venus GX device. The Remote Console and VRM features are painfully slow on this device. I have checked D-bus round trip, and it is increadibly high, it never goes below 300ms, and reaches 3000-4000ms every day when the MPPTs are working. I have checked the cabling, every communication line seems to be fine, lugs are crimped well and screws are torqued down correctly. What could cause such an issue? Did anybody experience similar problem, how can I resolve this?
In the system we have 2 VE.can MPPTs, 2 Multiplus II in parallel and 1 VE.direct BMV, so I don't think that the system is too complex for a Venus GX. Modbus TCP, MQTT services are disabled, normal OS is installed not large OS.
I checked Dbus round trip time for a long period, and it was quite normal before 22nd of July 2023, but after that it is constantly high. There was no firmware update at that time, and now after I updated the Venus OS from v2.94 to v3.11 the issue doesn't changed.
I have checked VRM diagnostics, and all values seemed to be okay, except the "Boot type" reporting "watchdog-EMAXLOAD (load average too high)", see table down below.
I could use any help in this topic as I never saw something similar. Nevertheless, the system still runs fine, but working with it (changing setup, check data and operation) is painful and VRM operations usually ends with an error because of no response or timeout from the Venus.
Date/ time
Device
Instance
Data attribute code
Data attribute
Value
24 minutes ago Gateway 0 d (1) gatewayID Venus OS
24 minutes ago Gateway 0 mi (386) Productid C002
24 minutes ago Gateway 0 mn (387) MachineName Venus GX
24 minutes ago Gateway 0 v (2) Fw Version v3.11
24 minutes ago Gateway 0 build (3) Fw Build date 20231009045315
24 minutes ago Gateway 0 ms (556) Machine serial number (removed for privacy)
24 minutes ago Gateway 0 cp (453) Capabilities MQTT-RPC; MQTT-RPC new firmware update command; VNC-SSH authentication; VregLink; Multiple generator start-stop services is supported; Accumulated generator runtime is available on the Tga attribute.; Has Dynamic ESS support (1111111)
24 minutes ago Gateway 0 dg (985) Default gateway Wifi
24 minutes ago Gateway 0 w (237) Boot type watchdog-EMAXLOAD (load average too high)
24 minutes ago Gateway 0 rss (154) Remote support Enabled
24 minutes ago Gateway 0 rsIpPort (543) Remote support IP and port (removed for privacy)
7 minutes ago Gateway 0 ipr (148) Remote ip address (removed for privacy)
24 minutes ago Gateway 0 ip (149) Local ip address 192.168.100.144
7 minutes ago Gateway 0 rtt (577) D-Bus Round-trip time 908 ms
24 minutes ago Gateway 0 au (150) Auto update Check
24 minutes ago Gateway 0 ut (151) Update to Official release
24 minutes ago Gateway 0 us (558) Update status Idle
24 minutes ago Gateway 0 fr (278) Free space rootfs 51895300 B
24 minutes ago Gateway 0 fd (279) Free space data 999559000 B
24 minutes ago Gateway 0 rwgm (582) Run withoud grid meter Yes
24 minutes ago Gateway 0 vl (256) VRM Log mode Enabled
7 minutes ago Gateway 0 TO (216) VRM Log time offset 1 s
24 minutes ago Gateway 0 sl (255) VRM Log interval 60 s
24 minutes ago Gateway 0 rdm (481) VRM Log ram disk mode normal
24 minutes ago Gateway 0 al (257) User access level User and installer
24 minutes ago Gateway 0 mb (258) Modbus TCP service Off
24 minutes ago Gateway 0 mql (572) MQTT Local (https) Off
24 minutes ago Gateway 0 mqli (573) MQTT Local (http) Off
24 minutes ago Gateway 0 tw (250) Two way communication On
24 minutes ago Gateway 0 dm (262) Demo modus on/off Off
24 minutes ago Gateway 0 tz (266) Time zone (removed for privacy)
7 minutes ago Gateway 0 H4bs (332) ESS battery life state BL Disabled (Low SoC)
24 minutes ago Gateway 0 bol (454) DVCC 1
7 minutes ago Gateway 0 H4as (333) ESS battery life SOC limit 40.0 %
24 minutes ago Gateway 0 H4ms (334) ESS Minimum SOC (unless grid fails) 30.0 %
7 minutes ago Gateway 0 sca (469) ESS Scheduled Charging Not active
24 minutes ago Gateway 0 Vl (269) VNC Local Enabled
24 minutes ago Gateway 0 Vi (270) VNC Internet Enabled
24 minutes ago Gateway 0 sb (261) Battery monitor setting com.victronenergy.battery/260
7 minutes ago Gateway 0 abs (263) Active battery service com.victronenergy.battery/260
24 minutes ago Gateway 0 shd (253) Has DC system No
24 minutes ago Gateway 0 mfp (595) Maximum configured feed-in power -1 W
24 minutes ago Gateway 0 si1 (251) AC Input 1 Grid
24 minutes ago Gateway 0 si2 (252) AC Input 2 Not available
24 minutes ago Gateway 0 shao (560) Has AC out system Yes
Gateway 0 lt (4) Latitude (removed for privacy)
Gateway 0 lg (5) Longitude (removed for privacy)
24 minutes ago Gateway 0 nr (692) NodeRed Off
24 minutes ago Gateway 0 sk (693) SignalK Off
24 minutes ago Gateway 0 H4of (741) Feed excess DC-coupled PV into the grid Off
24 minutes ago Gateway 0 H4pf (742) Feed AC-coupled PV into the grid Off
24 minutes ago Gateway 0 umc (743) DVCC user configured maximum charge current 140.0 A
24 minutes ago Gateway 0 umv (744) DVCC user configured maximum charge voltage 0.00 V
7 minutes ago Gateway 0 hp (470) Hung processes 0
7 minutes ago Gateway 0 zp (479) Zombie processes 0
24 minutes ago Gateway 0 dps (480) Data partition status fine
24 minutes ago Gateway 0 guiHash (1283) GUI Hash for Remote Console 0
24 minutes ago Gateway 0 H4M (1042) How ESS Multiphase regulation is done Individual phase
24 minutes ago Gateway 0 H4sp (1174) Grid setpoint 150 W
7 minutes ago Gateway 0 ssl (1175) Active SOC Limit 30 %
7 minutes ago Gateway 0 cRelay (306) Relay 1 state Open
7 minutes ago Gateway 0 cRelay1 (335) CCGX Relay 2 state Open
24 minutes ago Gateway 0 rf0 (1046) Relay 1 function Alarm relay
24 minutes ago Gateway 0 rf1 (1047) Relay 2 function Manual
24 minutes ago Gateway 0 dem (1270) Whether system accepts Dynamic ESS instructions. Off
24 minutes ago Gateway 0 dems (1275) Minimum battery SOC below which selling always stops 20.0 %
24 minutes ago Gateway 0 dec (1289) Dynamic ESS battery capacity 0.00 kWh
7 minutes ago Gateway 0 des (1272) Actual working state of Dynamic ESS Off
7 minutes ago Gateway 0 dee (1290) Dynamic ESS error code No Error
7 minutes ago Gateway 0 Gt (1018) Accumulated time for generic Generator 0
7 minutes ago VE.Bus System 261 ePR (519) Phase rotation Ok
7 minutes ago VE.Bus System 261 rt (581) Waiting to perform relay test OK
24 minutes ago VE.Bus System 261 vmk2 (6) mk2 version 1170216
24 minutes ago VE.Bus System 261 pmk2 (356) Mk2 product name MK3
24 minutes ago VE.Bus System 261 vvv (264) VE.Bus firmware version 502
24 minutes ago VE.Bus System 261 vvp (265) VE.Bus product id 2623
24 minutes ago VE.Bus System 261 vid (272) VE.Bus ShortIDs Two units configured in parallel
24 minutes ago VE.Bus System 261 vmc (316) VE.Bus connection VE.Bus
7 minutes ago VE.Bus System 261 IV1 (8) Input voltage phase 1 244.9 V
24 minutes ago VE.Bus System 261 vcn (1167) VE.Bus custom name
7 minutes ago VE.Bus System 261 II1 (11) Input current phase 1 3.7 A
7 minutes ago VE.Bus System 261 IF1 (14) Input frequency 1 50.10 Hz
7 minutes ago VE.Bus System 261 IP1 (17) Input power 1 517 W
7 minutes ago VE.Bus System 261 OV1 (20) Output voltage phase 1 244.9 V
7 minutes ago VE.Bus System 261 OI1 (23) Output current phase 1 2.2 A
7 minutes ago VE.Bus System 261 OF (26) Output frequency 50.0 Hz
7 minutes ago VE.Bus System 261 OP1 (29) Output power 1 471 W
7 minutes ago VE.Bus System 261 CV (32) Voltage 52.24 V
7 minutes ago VE.Bus System 261 CI (33) Current 0.1 A
24 minutes ago VE.Bus System 261 PC (34) Phase count 1
7 minutes ago VE.Bus System 261 AI (35) Active input AC Input 1
7 minutes ago VE.Bus System 261 AILIM (27) Active input current limit 16.00 A
7 minutes ago VE.Bus System 261 vIL1 (1168) AC Input 1 Current Limit 16.00 A
24 minutes ago VE.Bus System 261 vIA1 (1170) AC Input 1 Current Limit Adjustable Adjustable
2023-03-18 14:29:11 VE.Bus System 261 VSH (240) VE.Bus hidden SOC 94.0 %
7 minutes ago VE.Bus System 261 S (40) VE.Bus state Bulk
7 minutes ago VE.Bus System 261 ERR (41) VE.Bus Error No error
7 minutes ago VE.Bus System 261 s (79) Switch Position On
7 minutes ago VE.Bus System 261 dPV (388) Disable PV inverter PV enabled
24 minutes ago VE.Bus System 261 sa (1106) VE.Bus Switch Position Adjustable Mode is adjustable
7 minutes ago VE.Bus System 261 eT (42) Temperature Ok
7 minutes ago VE.Bus System 261 eL (43) Low battery Ok
7 minutes ago VE.Bus System 261 eO (44) Overload Ok
7 minutes ago VE.Bus System 261 eTS (389) Temperatur sensor alarm Ok
7 minutes ago VE.Bus System 261 aps1 (280) Hub4 power setpoint phase 1 472 W
7 minutes ago VE.Bus System 261 eVS (390) Voltage sensor alarm Ok
7 minutes ago VE.Bus System 261 H4S (284) Hub4 sustain Off
7 minutes ago VE.Bus System 261 Hcsp (396) Charge voltage setpoint 61.60 V
7 minutes ago VE.Bus System 261 t1 (317) Energy AcIn1 to Inverter 0.00 kWh
7 minutes ago VE.Bus System 261 t2 (318) Energy ACIn2 to Inverter 0.00 kWh
7 minutes ago VE.Bus System 261 t3 (319) Energy ACIn1 to AcOut 0.67 kWh
7 minutes ago VE.Bus System 261 t4 (320) Energy ACIn2 to AcOut 0.00 kWh
7 minutes ago VE.Bus System 261 t5 (321) Energy Inverter to AcIn1 0.00 kWh
7 minutes ago VE.Bus System 261 t6 (322) Energy Inverter to AcIn2 0.00 kWh
7 minutes ago VE.Bus System 261 t7 (323) Energy AcOut to AcIn1 0.00 kWh
7 minutes ago VE.Bus System 261 t8 (324) Energy AcOut to AcIn2 0.00 kWh
7 minutes ago VE.Bus System 261 t9 (325) Inverter To AcOut 0.07 kWh
7 minutes ago VE.Bus System 261 t10 (326) AcOut to Inverter 0.00 kWh
24 minutes ago VE.Bus System 261 asT0 (357) Device 0 assistant list 184
24 minutes ago VE.Bus System 261 asT3 (360) Device 3 assistant list 184
7 minutes ago VE.Bus System 261 vbc (392) VE.Bus BMS allows battery to be charged Yes
7 minutes ago VE.Bus System 261 vbd (393) VE.Bus BMS allows battery to be discharged Yes
24 minutes ago VE.Bus System 261 vbx (394) VE.Bus BMS is expected No
7 minutes ago VE.Bus System 261 vbe (395) VE.Bus BMS error No
7 minutes ago VE.Bus System 261 eR (523) High DC Ripple Ok
7 minutes ago VE.Bus System 261 eT1 (344) Temperature L1 Ok
7 minutes ago VE.Bus System 261 eL1 (345) Low battery L1 Ok
7 minutes ago VE.Bus System 261 eO1 (346) Overload L1 Ok
7 minutes ago VE.Bus System 261 eR1 (347) High DC Ripple L1 Ok
7 minutes ago VE.Bus System 261 eT2 (348) Temperature L2 Ok
7 minutes ago VE.Bus System 261 eL2 (349) Low battery L2 Ok
7 minutes ago VE.Bus System 261 eO2 (350) Overload L2 Ok
7 minutes ago VE.Bus System 261 eR2 (351) High DC Ripple L2 Ok
7 minutes ago VE.Bus System 261 eT3 (352) Temperature L3 Ok
7 minutes ago VE.Bus System 261 eL3 (353) Low battery L3 Ok
7 minutes ago VE.Bus System 261 eO3 (354) Overload L3 Ok
7 minutes ago VE.Bus System 261 eR3 (355) High DC Ripple L3 Ok
7 minutes ago VE.Bus System 261 vcs (557) Charge state Bulk
7 minutes ago VE.Bus System 261 vbl (1267) BMS lost No alarm
7 minutes ago VE.Bus System 261 q0 (544) VE.Bus netw. error count - unit 1 2
7 minutes ago VE.Bus System 261 q3 (547) VE.Bus netw. error count - unit 4 1
7 minutes ago VE.Bus System 261 eV (649) High DC Voltage OK
7 minutes ago VE.Bus System 261 eC (650) High DC Current OK
7 minutes ago VE.Bus System 261 v0 (651) Device 0 High DC Voltage 0
7 minutes ago VE.Bus System 261 v3 (655) Device 3 High DC Voltage 0
7 minutes ago VE.Bus System 261 d0 (664) Device 0 High DC Current 0
7 minutes ago VE.Bus System 261 d3 (667) Device 3 High DC Current 0
7 minutes ago VE.Bus System 261 ia (677) Ignore AC input Not ignored
24 minutes ago VE.Bus System 261 vs0 (1107) Serial number of 1st device (removed for privacy)
24 minutes ago VE.Bus System 261 vs3 (1122) Serial number of 4th device (removed for privacy)
38 minutes ago VE.Bus System 261 ns0 (678) Interface protection log 0 (1000)
7 minutes ago VE.Bus System 261 p0 (719) Device 0 Power-pack pre-overload 0
7 minutes ago VE.Bus System 261 p3 (722) Device 3 Power-pack pre-overload 0
7 minutes ago VE.Bus System 261 H4f1 (732) L1 Frequency Variation OK
7 minutes ago VE.Bus System 261 H4l1 (1039) Max Feedin Power L1 65532 W
7 minutes ago VE.Bus System 261 vu (1176) Uptime of the 1st device 1740 s
7 minutes ago VE.Bus System 261 vu3 (1179) Uptime of the 4th device 1740 s
7 minutes ago VE.Bus System 261 vr0 (1138) VE.Bus Voltage ripple - unit 1 0.00 V
7 minutes ago VE.Bus System 261 vr3 (1141) VE.Bus Voltage ripple - unit 4 0.00 V
7 minutes ago VE.Bus System 261 vt0 (1150) VE.Bus Terminal voltage- unit 1 52.12 V
7 minutes ago VE.Bus System 261 vt3 (1153) VE.Bus Terminal voltage - unit 4 52.34 V
7 minutes ago VE.Bus System 261 vu0 (1162) VE.Bus sense voltage - unit 1 52.24 V
24 minutes ago Battery Monitor 260 Bcn (585) Battery custom name
24 minutes ago Battery Monitor 260 BM (45) Model 203
24 minutes ago Battery Monitor 260 BV (46) Firmware version v3.11
24 minutes ago Battery Monitor 260 BSN (114) Serial Number (removed for privacy)
7 minutes ago Battery Monitor 260 V (47) Voltage 52.25 V
7 minutes ago Battery Monitor 260 I (49) Current 0.10 A
7 minutes ago Battery Monitor 260 CE (50) Consumed Amphours -206.70 Ah
7 minutes ago Battery Monitor 260 SOC (51) State of charge 29.0 %
7 minutes ago Battery Monitor 260 TTG (52) Time to go 0.00 h
7 minutes ago Battery Monitor 260 AL (119) Low voltage alarm No alarm
7 minutes ago Battery Monitor 260 AH (120) High voltage alarm No alarm
7 minutes ago Battery Monitor 260 ALS (121) Low starter-voltage alarm No alarm
7 minutes ago Battery Monitor 260 AHS (122) High starter-voltage alarm No alarm
7 minutes ago Battery Monitor 260 ASoc (123) Low state-of-charge alarm No alarm
7 minutes ago Battery Monitor 260 ALT (124) Low battery temperature alarm No alarm
7 minutes ago Battery Monitor 260 AHT (125) High battery temperature alarm No alarm
7 minutes ago Battery Monitor 260 AM (126) Mid-voltage alarm No alarm
7 minutes ago Battery Monitor 260 Relay (54) Relay status Open
24 minutes ago Battery Monitor 260 H1 (55) Deepest discharge -218.50 Ah
10 minutes ago Battery Monitor 260 H2 (56) Last discharge -206.70 Ah
24 minutes ago Battery Monitor 260 H3 (57) Average discharge -105.90 Ah
24 minutes ago Battery Monitor 260 H4 (58) Charge cycles 164.00
24 minutes ago Battery Monitor 260 H5 (59) Full discharges 0.00
10 minutes ago Battery Monitor 260 H6 (60) Total Ah drawn -28701.30 Ah
24 minutes ago Battery Monitor 260 H7 (61) Minimum voltage 40.89 V
24 minutes ago Battery Monitor 260 H8 (62) Maximum voltage 64.76 V
7 minutes ago Battery Monitor 260 H9 (63) Time since last full charge 1.20
24 minutes ago Battery Monitor 260 H10 (64) Automatic syncs 116.00
24 minutes ago Battery Monitor 260 H11 (65) Low voltage alarms 0.00
24 minutes ago Battery Monitor 260 H12 (66) High voltage alarms 0.00
10 minutes ago Battery Monitor 260 H21 (244) Discharged Energy 1512.81 kWh
24 minutes ago Battery Monitor 260 H22 (245) Charged Energy 1628.10 kWh
7 minutes ago Battery Monitor 260 dH21 (338) Discharged Energy delta 0.05 kWh
3 hours ago Battery Monitor 260 dH22 (339) Charged Energy delta 0.01 kWh
7 minutes ago Solar Charger 1 ScOR (583) Solar charger off reason No input power (1)
24 minutes ago Solar Charger 1 Sccn (586) Solar charger custom name (removed for privacy)
24 minutes ago Solar Charger 1 ScM (106) Solarcharger model a115
24 minutes ago Solar Charger 1 ScVt (80) Solar charger version v3.14
24 minutes ago Solar Charger 1 ScSN (118) Solar charger serial number (removed for privacy)
7 minutes ago Solar Charger 1 ScV (81) Voltage 52.2 V
24 minutes ago Solar Charger 1 Scvs (1105) Voltage setting 48
7 minutes ago Solar Charger 1 ScI (82) Current 0.0 A
7 minutes ago Solar Charger 1 ScW (107) Battery watts 0 W
7 minutes ago Solar Charger 1 SLs (241) Load state On
7 minutes ago Solar Charger 1 Scs (84) Charger on/off On
7 minutes ago Solar Charger 1 ScS (85) Charge state Off
7 minutes ago Solar Charger 1 PVV (86) PV voltage 0.7 V
7 minutes ago Solar Charger 1 PVP (442) PV power 0 W
7 minutes ago Solar Charger 1 ScMm (518) MPPT State Off
7 minutes ago Solar Charger 1 SRelay (90) Relay on the charger Open
7 minutes ago Solar Charger 1 SceL (92) Low batt. voltage alarm No alarm
7 minutes ago Solar Charger 1 SceH (93) High batt. voltage alarm No alarm
7 minutes ago Solar Charger 1 YT (94) Yield today 2.23 kWh
7 minutes ago Solar Charger 1 MCPT (95) Maximum charge power today 609 W
7 minutes ago Solar Charger 1 YY (96) Yield yesterday 13.38 kWh
7 minutes ago Solar Charger 1 MCPY (97) Maximum charge power yesterday 2508 W
7 minutes ago Solar Charger 1 ScERR (98) Error code No error
7 minutes ago Solar Charger 1 YU (285) User yield 1875.86 kWh
4 hours ago Solar Charger 1 dYU (340) User yield delta 0.01 kWh
7 minutes ago Solar Charger 2 ScOR (583) Solar charger off reason No input power (1)
24 minutes ago Solar Charger 2 Sccn (586) Solar charger custom name (removed for privacy)
24 minutes ago Solar Charger 2 ScM (106) Solarcharger model a115
24 minutes ago Solar Charger 2 ScVt (80) Solar charger version v3.14
24 minutes ago Solar Charger 2 ScSN (118) Solar charger serial number (removed for privacy)
7 minutes ago Solar Charger 2 ScV (81) Voltage 52.2 V
24 minutes ago Solar Charger 2 Scvs (1105) Voltage setting 48
7 minutes ago Solar Charger 2 ScI (82) Current 0.0 A
7 minutes ago Solar Charger 2 ScW (107) Battery watts 0 W
7 minutes ago Solar Charger 2 SLs (241) Load state On
7 minutes ago Solar Charger 2 Scs (84) Charger on/off On
7 minutes ago Solar Charger 2 ScS (85) Charge state Off
7 minutes ago Solar Charger 2 PVV (86) PV voltage 0.9 V
7 minutes ago Solar Charger 2 PVP (442) PV power 0 W
7 minutes ago Solar Charger 2 ScMm (518) MPPT State Off
7 minutes ago Solar Charger 2 SRelay (90) Relay on the charger Open
7 minutes ago Solar Charger 2 SceL (92) Low batt. voltage alarm No alarm
7 minutes ago Solar Charger 2 SceH (93) High batt. voltage alarm No alarm
7 minutes ago Solar Charger 2 YT (94) Yield today 2.17 kWh
7 minutes ago Solar Charger 2 MCPT (95) Maximum charge power today 597 W
7 minutes ago Solar Charger 2 YY (96) Yield yesterday 12.49 kWh
7 minutes ago Solar Charger 2 MCPY (97) Maximum charge power yesterday 2344 W
7 minutes ago Solar Charger 2 ScERR (98) Error code No error
7 minutes ago Solar Charger 2 YU (285) User yield 1822.64 kWh
4 hours ago Solar Charger 2 dYU (340) User yield delta 0.01 kWh
7 minutes ago System overview 0 i1 (564) AC Consumption on Input L1 0 W
7 minutes ago System overview 0 o1 (567) AC Consumption on Output L1 471 W
21 minutes ago System overview 0 st (570) System type ESS
7 minutes ago System overview 0 ss (571) System state Bulk
7 minutes ago System overview 0 evc (578) Effective charge voltage 61.6 V
2 hours ago System overview 0 Gb (100) Grid to battery 0.02 kWh
7 minutes ago System overview 0 Gc (101) Grid to consumers 0.36 kWh
4 hours ago System overview 0 Pb (102) PV to battery 0.02 kWh
2023-10-15 12:00:12 System overview 0 Pg (103) PV to grid 0.04 kWh
7 minutes ago System overview 0 ssls (472) #1 Low SOC; discharge disabled On
7 minutes ago System overview 0 ssbl (473) #2 BatteryLife is active Off
7 minutes ago System overview 0 ssdc (475) #3 Charge disabled by BMS Off
7 minutes ago System overview 0 ssdd (474) #4 Discharge disabled by BMS Off
7 minutes ago System overview 0 sssc (476) #5 Slow charge is active Off
7 minutes ago System overview 0 ssuc (477) #6 Charge disabled by user setting Off
7 minutes ago System overview 0 ssud (478) #7 Discharge disabled by user setting Off
4 hours ago System overview 0 Pc (104) PV to consumers 0.02 kWh
7 minutes ago System overview 0 Bc (105) Battery to consumers 0.04 kWh
2023-10-15 08:00:28 System overview 0 Bg (108) Battery to grid 0.02 kWh
7 minutes ago System overview 0 Pdc (113) PV - DC-coupled 0 W
7 minutes ago System overview 0 a1 (131) AC Consumption L1 471 W
7 minutes ago System overview 0 g1 (134) Grid L1 511 W
7 minutes ago System overview 0 bv (143) Voltage 52.25 V
7 minutes ago System overview 0 bc (147) Current 0.00 A
7 minutes ago System overview 0 vc (153) VE.Bus charge current 0.0 A
7 minutes ago System overview 0 bp (243) Battery Power 0 W
7 minutes ago System overview 0 vp (254) VE.Bus charge power 40 W
7 minutes ago System overview 0 bs (144) Battery SOC 29.0 %
7 minutes ago System overview 0 bst (215) Battery state idle
7 minutes ago System overview 0 ba (145) Battery Consumed Amphours -206.70 Ah
8 minutes ago System overview 0 bt (146) Battery Time to Go 240.00 h
7 minutes ago System overview 0 Amb (579) DVCC Multiple batteries alarm No alarm
7 minutes ago System overview 0 Af (580) GX Error #48 DVCC with incompatible firmware No alarm
7 minutes ago System overview 0 H4m (676) No grid meter alarm OK
15 minutes ago System overview 0 To (531) Time off 51.00 s
7 minutes ago System overview 0 Tg (533) Time grid 553.00 s
35 minutes ago System overview 0 Ti (534) Time inverting 511.00 s
7 minutes ago System overview 0 AIS (471) AC-Input Grid
7 minutes ago System overview 0 ic0 (825) AC Input 1 connected Connected
7 minutes ago System overview 0 id0 (827) AC Input 1 device instance 261
7 minutes ago System overview 0 vi0 (918) AC Input 1 VRM device instance 261
7 minutes ago System overview 0 ist0 (829) AC Input 1 service type vebus
7 minutes ago System overview 0 is0 (831) AC Input 1 source Grid
7 minutes ago System overview 0 ini (833) Number of AC Inputs 1
7 minutes ago System overview 261 Agl (559) Grid alarm Grid ok
Venus GX - VGX
foreignerpv avatar image
foreignerpv answered ·
Hello, I am also working on a round trip time anomaly. However, this is not as large as yours.
In my system: When an RTP peak occurs, the power production of the MPPTs drops during the RTP peak time.
Now there is the question: How is RTP defined? From my understanding, a response time is measured from the gateway (WLAN interface or Ethernet rj45 interface) to part of the processing unit. Both sides are addressed. The route is inside the GX device or Cerbo. Apparently the processor is stressed by an unknown event that we don't know about. In your case, I would deactivate certain devices during troubleshooting and observe RTB. - Cancel the parallel connection of the Multiplus. - Disable MTPs - Disconnect grid connection
I think your RTP problem is a very interesting case
so long Wolfgang
