bivaccamper avatar image
bivaccamper asked
Scalable system
I'm planning to build three vans with the same system on each.
The system on each van will be:
- 24v Battery
- Multiplus / Quattro 24/3000
- And maybe, an mppt, a BMV and a Venus GX
My question is, there is a way so I could connect and reconfigure the settings of the systems to work together so 3 multis on single phase o 3 multis in three phase?
My big concern is about monitoring the batteries.
If I use the battery monitor on each multiplus they can run each one on its battery or they have to run both with the same battery and use a BMV?
There is a way so each multiplus is working with its battery but connected with the other multiplus? Each multiplus can take care of its own battery?
I asume that this is not possible with a Venus and three BMV or three Venus connected together, sharing data, no?
Thanks
MultiPlus Quattro Inverter Chargerbattery charging3 phase
wkirby avatar image
wkirby answered ·
I'm afraid what you want to do is not possible.
When you have a three phase or parallel system the units work as one and show up on a single Venus device as one unit. You can only have one Venus device in a system.
Besides only being able to have one battery monitor in a system, you cannot have each MultiPlus on its own battery when configured as a three phase or parallel system.
bivaccamper answered ·
As for the Venus I already know that. My big concern is about battery monitoring. Any idea on how this can be done?
