Hi.
I have two arrays in two controllers charging sopzs batteries. Setting equalization separately am I sure the equalization will work simultaneously at the two controllers?
P.S.I have algorithm 2 for charging.
Hi.
Hi Yorgos, yes that will work. You’ll need to enable it on both chargers; as those models don’t have a synchronised charging feature (yet).
But depending on your settings and size of the bank, doing equalise with just one of the two might be enough.
8 People are following this question.
