jbluetooth avatar image
jbluetooth asked
Help choosing MPPT charger and wiring for RV solar array, Renogy panels
I plan to add (4) Renogy 320w 24v panels to my 5th wheel. Batteries are (3) 230ah 12V lithium. Panel specs:
Electrical Data:
Maximum Power at STC*: 320 W
Optimum Operating Voltage (Vmp ): 33.7 V
Optimum Operating Current (Imp ): 9.50 A
Open Circuit Voltage (Voc ): 40.1V
Short Circuit Current (Isc ): 10.08 A
2 of the panels will be on the front part of the roof, 1 in the middle, and 1 a little back from middle. I want to make sure to generate as much power when camping in partial shade as the sun passes over, so I was thinking either all panels in parallel if I can get away with it, or maybe the front 2 in series and the middle/back 2 in series.
Plugging this in to the Victron calculator, It recommended the 150/70 for either option. Anything I'm missing? Any big reason it's worth doing series-parallel over all parallel to make sure I'm getting some charge if a lot of the array is shaded as the sun passes over if I'm camping in trees? Thank you for your help
Jesse
MPPT SmartSolarSolar Panelvictron products
ahtrimble avatar image
ahtrimble answered ·
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
