I have several temperature graphs on my VRM , all now no longer showing traces , looks like there were changes made to VRM resulting in this . Temperature data is present in CSV file.
Hi @PeterM,
Thanks for the report, I've forwarded it on to the VRM team.
In the mean time you can work around it by creating a custom widget for temperature, the data still shows up correctly there.
I'm seeing the same problem - with both raw analog temperature inputs and with Ruuvi sensors. It only started happening ibn the past week or so.
61 People are following this question.
