Fideri avatar image
Fideri asked
Is BSL B-LFP48-200E supported?
Dear All.
Victron says BSLBatt is compatible but only lists model B-LFP48-200PW (power wall model). The similar B-LFP48-200E (rack mount model) is not listed. As far as I can tell, the only difference between the two is the form factor. Victron lists a few other rack mount models like the similar B-LFP48-160E.
Is the B-LFP48-200E compatible?
Fideri
Lithium Batterybslbatt
Alexandra avatar image
Alexandra answered ·
@Fideri
According to the spec sheet it uses the same charged voltages etc as the other models. So I don't see why not.
So the difference is likely just capacity.
I doubt the re invented the wheel for this model either so would work the same way as all the others.
Fideri avatar image Fideri commented ·
Your reasoning sounds correct. And according to BSL Batt, they are all the same. I will take the plunge.
Battery Compatibility
Victron & BSLBATT Lithium batteries
