I'm interested in installing a wireless AC Sensor. Any sourcing suggestions for Bluetooth models? If not, what is the CERBO configured to use for this function?
Thank you
Thank you
@Rulexi, what I found is this:
a) The Energy Meters VM from Victron (here)
b) The Energy Meter Selection Guide (here). Read: All other Energy Meters listed here connect to a GX device via RS485 either through a wired connection via a RS485 to USB interface or wirelessly via a Zigbee to USB and Zigbee to RS485 converters. Its data is then displayed on a GX device and the VRM portal.
c) The Product data sheet (here)
hope this helps, cheers
I have now found another solution myself, which I will install.
Please take a look at the manufacturer Shelly.com. There are various sensors and switches that can be monitored, configured and switched via Bluetooth and WiFi. There are no wishes left unfulfilled when it comes to AC and DC themes. I can only recommend the products.
There is also integration into the Cerbo (see here).
This helps, thank you
39 People are following this question.
