ubi avatar image
ubi asked
Multi RS & Lynx Shunt with different SOC
I recently upgraded my system with a Lynx Shunt and now the Multi RS shows his own SOC (few % more). I have a 10% dischage limit, but today the Lynx Shunt showed 6% but the Multi RS (SOC 11%) didn't turned off. Before the upgrade the Multi RS used the Smart Shunt's SOC.
System before upgrade:
Multi RS Solar 450/80
Smart Shunt
MPPT 150/45
MPPT 100/20
2x 14kW Lifepo4 Battery
Cerbo GX
System after upgrade:
Lynx Shunt + Lynx Power In
MPPT 150/45
MPPT 100/20
Cerbo GX
I can chose in the Cerbo system setup -> Battery monitor which SOC should the system use. After a complete reboot it has no effect. I can't use the Multi RS SOC because I have two more MPPTs.
What could be the problem? Do you have any suggestions? Is the Multi RS compatible with the Lynx Shunt?
Thank you.
SOClynx shuntMulti RS
4 comments
Hi @UBI,
Thanks for the report, I'll see what I can find out.
ubi avatar image ubi Guy Stewart (Victron Community Manager) ♦♦ commented ·
Another interesting fact: When I use the BMS as the "Battery monitor" in the Cerbo system setup, the Multi RS uses it immediately. It only doesn't work with the Lynx shunt.
Hi @UBI
Indeed there appears to be a specific limitation with the Lynx Shunt and RS inverters.
The engineers are now aware and I’ve just asked them for an update on the situation.
semlohnhoj avatar image semlohnhoj Guy Stewart (Victron Community Manager) ♦♦ commented ·
I use a lynx shunt and two Multi RS Solar units and all three show different SOC values
Martin (Victron Energy) avatar image
Martin (Victron Energy) answered ·
We just released firmware v1.10 for the Lynx Shunt VE.Can which addresses this issue. It it available on Victron Professional and through the VRM firmware update feature.
semlohnhoj avatar image semlohnhoj commented ·
I had to reset the SOC after installing the firmware update but I can confirm that the update has resolved the issue for me. Both of my Multi RS Solar units now show the same SOC as the shunt.
2 Likes 2 ·
Lynx Shunt VE Can online manual
Mutli RS Solar Datasheet
Mutli RS Manual
