towatai avatar image
towatai asked
MPPT loses connection sporadically
I own an Easysolar II GX 24/3000 and the internally installed MPPT seems to lose connection sporadically. Sometimes it runs for days, sometimes it happens several times a day and then only a reboot of the GX helps. Very very annoying and certainly not in the spirit of the inventor. The problem is now over umpteen firmware versions and I am so slowly but surely quite annoyed. It would be nice if someone here has a solution, because the system otherwise runs great. I'm also glad to provide logs, if you tell me where I can find them and which ones they should be exactly.
MPPT SmartSolarerrorconnection issue
Mike Dorsett avatar image Mike Dorsett commented ·
I'd try either changing the ve-direct cable from the gx to the MPPt, or plug the cable into an alternate Ve-direct port on the Gx. Not impossible for the cable to have a dodgy connector - these are very small.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
