sv-hydrate avatar image
sv-hydrate asked
Shunt interface
Hi all,
I have a leftover shunt which was part of a BMV 712, which I'd like to repurpose to measure the input from my alternators. Ideally I'd like to plug the shunt directly into a Cerbo-s GX, but the shunt has an RJ12 plug, does anyone know if it's VE.Direct with a wog plug (and what the pin-outs are), or is it something else, in which case I guess I'll have to use the VE.Direct port in the 712 itself.
Just doesn't seem to be any point in having the monitor when there's a Cerbo screen there showing the same data..
Cheers,
Trev
BMV Battery MonitorVE.Direct
Michelle Konzack avatar image Michelle Konzack commented ·
You can ask your reseller or distributor for the SmartShunt electronic as Spare Part.
I have even 3 of them laying around because I bought my BMVs in a time (2018) where the SmartShunt did not exist and bought the 1000A shunts.
A new SmartShunt cost 146€+ VAT, but maybe I can get three electronics as spare parts less expensive.
That's not a SmartShunt it's just the shunt that is delivered with the BMV.
The RJ11 port is NOT VE.direct. That port can only be used to connect shunt to the BMV.
You need to connect the BMV to the Cerbo with a VE.direct cable.
sv-hydrate answered ·
I thought that might be the case, but hoped I was was wrong..
Thank you..
