zygao avatar image
zygao asked
QUATTRO Ground Relay Voltage NO OUTPUT
I am troubleshooting the ground relay function. I have a QUATTRO 24/5000/100 and an autotransformer. The autotransformer is not bonding neutral to ground when inverting, even though I have the ground relay wiring in the place and the ground relay option unchecked in the VICTRON APP. And I put a multimeter in the ground relay on the QUATTRO GND relay, there is no output.
MultiPlus Quattro Inverter ChargerGroundingAutotransformer
rona avatar image
rona answered ·
Hi did you set the hidden slide switches on the bottom of the quattro ?.Look in the manual at appendix A for more details.
