raphael avatar image
raphael asked
Feature Request: Reset SOC to 0%, if Voltage is low
I'd love to see a option in the SmartShunt, to reset the SOC to 0%, if the battery voltage drops below a set threshold (e.g. 50V) and the discharge current is lower than a set threshold (e.g. 10A).
During the winter months, in a ESS-System, the SOC can get inaccurate, if the battery is not being charged to 100% SOC every now and than. I once ran into this situation: a customer asked me, why the battery low voltage warning is on, while the displayed SOC was 20%...I had to manually set the SOC to 0%.
If the voltage drops below 50V (16S LiFePo4), I want the SOC to be reset to 0%. Than the ESS can charge back to 20% automatically and there is no low voltage alarm.
I know, that there are plenty of workarounds:
(1) In the ESS, I can select "Optimized (with BatteryLife)". But this feature also has some issues / drawbacks.
(2) I use Scheduled charging once a week to charge to 100%.
(3) I could set the Sustain Voltge in the MP-II above 50V and the Dynamic cut-off @ 0.005C to 50V.
In a OFF-GRID-Installation, this feature would be handy...people always trust the SOC, but if it is not accurate, it gets suddenly dark, while the BMV tells them, that there is 10% or 20% remaining.
BMV Battery MonitorSmartShuntSOC
Is the low voltage cut off/shutdown 50v?
Battery low warnings are either ESS dynamic cut off voltages or the warning set on the inverter tab.
Is there a possibility that the battery is shutting down due to imbalance not low SOC?
