Looking for some feedback on my design before implementing it
1. The community is not for discussing system designs you should ask your local Victron dealer/installer about that.
2. Without more information it looks like a pretty basic system, nothing special or complicated.
@SVJE my only comment is that the Smart BMS 12/200 is designed to be used with the Victron batteries and yo0u have not highlighted whose batteries you are using. It requires the signal from the Victron Smart Lithium batteries to work correctly, so may not be your best choice of device to control charging from batteries. I suggest you read the manuals and look at the associated schematics on the Victron site to get an understanding of how the Victron equipment should be used.
@Bathnm TY! I had read the info and for some reason did not see that at all…now I have to go sell the smart BMS. Any recommendations to put in that spot to protect the batteries from the alternator?
43 People are following this question.
