Hi all, I have a 100ah agm battery with Victron smart shunt and ip22 mains charger that are smart ve network connected, the ip22 is set for adaptive absorption, do I need to set the tail current or will the charger automatically set that?
Your post is lacking details. The best answer for the battery is to contact the manufacturer or search their website for their recommended settings.
Have you read any manuals? They will provide setup information. You can find Victron manuals here: https://www.victronenergy.com/support-and-downloads/manuals
As for IP22 that only states the device's ingress protection rating (like dust and liquids) of whatever you have.
The charger will not set the tail current in the shunt. All the shunt settings must be made by you.
However the default of 4% is a good starting point for AGM
Many thanks for your reply, I have set tail current at 4% in shunt but was wondering if I need to set tail current in expert mode in the absorption setting in the blue smart ip 22 mains charger?
SmartShunt Installation Manual
SmartShunt Quick Installation Guide
Blue Smart IP22 Product Page
Blue Smart IP22 230v datasheet
Blue Smart IP22 120v datasheet
Blue Smart 120v manual download
Did You Know? - use the blue smart as a power supply (video link)
History and Settings for Blue Smart Chargers in Victron Connect (video link)
47 People are following this question.
