Thomas avatar image
Thomas asked
2 Multiplus II in paralell single phase in 3phase system
The idea is to have 2 Multplus II connected in paralell on a 3 phase system. Essential load on AC1 and non essential load on AC2 obove certain SOC of the batteries with help of the assistant. (Aircondition and Water boiler)
One phase is limited to 16A therefore the idea is to use the power assist to use batteries on peak obove 16A of AC1 and L1.
1. Does this work?
2. Will AC1 run on Solar only when Power is enough, not taking power from the grid when using power assist?
3 phasemultiplus in parallel
nickdb avatar image
nickdb answered ·
