What is a BlueSolar MPPT 100/15 Charge Controller's minimum input voltage. I have a Bluetti PV120 solar panel 19v max can I use it on this controller? It usually outputs 100W avg. when I use it. I want to charge a 12v liefpo4 battery.
Thanks I found it the simple answer. I know how solar works I just needed the numbers.
The minimum input voltage should be at least 5 volts over your battery voltage.
If the voltage is not high enough, the charge controller will not start.
Just to put some numbers to it. If your 12V battery is partly charged at, say, 13V MPPT charging will not start until the panels reach 18V.
39 People are following this question.
