schwuppe avatar image
schwuppe asked
get node red error status
there are plenty of node red nodes that give me assorted error status.
I want a general error status that combines for example BMS error, VE Bus error, temerature warnings etc.
Which node shall I use therefore ? Thank you
Node-RED
derrick thomas avatar image
derrick thomas answered ·
Are you looking for something to display errors on a node red dashboard? If so, you can use the appropriate victron input nodes to catch the errors and then use a change node or a function node to change from the numerical value to a text of the actual error, and then send the text to a dashboard node. There is also a dashboard pop-up node which can provide a pop-up (output provided by the previously mentioned process) on any open tab of your dashboard when there is an error present.
schwuppe answered ·
I want to forward a general unspecific failure/warning notice over mqtt. The can then do further investigaton.
I got a battery system, voltage measurement ect.
I do not want to search for every possible warning, maybe later when I expand my system forget new ones.
Is there a combined error/failure/... info in one of the node red nodes?
thanks
derrick thomas avatar image derrick thomas commented ·
"Is there a combined error/failure/... info in one of the node red nodes?
thanks"
Not that I am aware of. Each device in the system is responsible for reporting it's own errors, warnings and alarms.
schwuppe avatar image schwuppe derrick thomas commented ·
ok
