Hi there, i would like to instal 3 12v 200 ah lithium batteries ( 36 volt sys.) for my minn kota , and want to charge them from my engine and also from shore power, can u help me pls about what i need
thanks
thanks
Hi @osman, welcome to the Community!
Unfortunately 36v configuration of Victron LFP batteries is not supported, so Victron LFP batteries will not be the solution for your particular application. For more information, you can see the datasheet available here
dear Justin , thanks for responce ,
can we charge them with 3 seperate charger ?
3 batteries are connected serial but ,at the same time if we connect one by one 3 seperate charger to each battery , what are tou thinking like that ?
just my opinion
@osman it's not just a question of charging them, it's that they may not be used in that configuration. Certain Victron battery banks may be series-connected to 24 or 48V while others may not be series-connected at all, but 36v is not an option in any case. Victron batteries are not the solution for your particular installation, unfortunately.
Do you need 36V for some special application or you just happen to have three 12V batteries and want to use them all in one system?
need 36 volt for some application , but i want to use victron lithium
my boat have 2 engine with 12 volt alternator,
i want to charge them with shore power and boat alternator
how can i do this with all victron energy system
48 People are following this question.
