broesel avatar image
broesel asked
equal strings on MPPT 450/200 not producing the same
Hi!
I have a Strange effect on a new MPPT 450/200.
There 4 identical Strings attached to the trackers.
When Sun starts in the morning you see all trackers rising identically, excpet tracker 2: It stays round about 10-20W below the other 3.
When i swap the strings, you see that it is not the string itself, because it stays on tracker 2 with the lower Wattage.
So somehow the MPPT gets less power on its Tracker 2 - during the day this normalises usually.
Anyone has seen the same or an idea what it might be?
Best regards
Broesel
mppt rs
Is this a typo?
broesel avatar image broesel seb71 commented ·
No,
while the others produce for example 700W the tracker two only produces 680W.
Sometimes it is evenn 40W below.
Best regards.
Hi @Broesel,
A small variation between the strings is nothing to worry about.
I would guess the most likely reason is a variation in the accuracy or calibration of the component that is doing that measurement.
