mjs500 avatar image
mjs500 asked
multiplus ii input port re G100 and AC PV
Logic interface (input port) Confirm that an input port is provided and can be used to shut down the module. YES Provide high level description of logic interface, e.g. details in 11.1.3.1 such as AC or DC signal (the additional comments box below can be used) YES *When the switch is closed the Micro-generator can operate normally. When the switch is opened the Micro-generator will reduce its Active Power to zero within 5 s. The signal from the Micro-generator that is being switched is DC (maximum value 5V).
i seen this in the G89 - G99 sheet but have not see it in manuals can Victron shed light on this programable input vesical ?
multiplus in parallel
