rygar avatar image
rygar asked
Multiple start/stop charging. Good for charger and batteries?
Hello community!
The following sub-system might be given:
Charger (might be a VICTRON CENTAUR 12/30) + 2x12v Batteries in series. The batteries should be charged if there is sun. For this reason, I can swich the charging wire ON/OFF with two relays via a Shelly 3em or something similar.
In short: If there is enough Sun, the batteries should be charged, otherways not.
For better understanding:
Question:
Is there a problem for charger or batteries (LiFePo4), interrupting the charging process multiple times per day, when sun and clouds are changing?
Is there any other aspect to take into account?
Best Michael
battery chargingbatterylife
VictronConnect VE.Bus charging manual
