Russel avatar image
Russel asked
Lynx shunt always flashing green
Greetings,
Green LED on Lynx shunt continuously flashes. This means initializing, per the manual. It will fast flash, then stay continuously lit for 2 secs and then it repeats this.
It WAS working fine. It showed up in the Cerbo GX. It was working for days.
It’s the only VE.Can device in the system, other than the Cerbo GX.
I swapped out ethernet cables. I moved to a different connector. I have the terminators plugged in.
What gives??
Russ
lynx shunt
virtualburton avatar image virtualburton commented ·
I have exactly the same issue. Has anyone found a solution for this?
Lynx Shunt VE Can online manual
