....while the solar panels are putting out good power? Or should I use a seperate port BMS so that only the load is cut off?
You should always switch each device with a separate contact. Devices' inputs may be at different reference levels or open circuit Voltage levels.
If your BMS has only one output the use it to drive a relay with two separate contacts so that the contacts being used to enable /disable each device will be isolated.
You could also use a single output BMS to drive two opto-isolators if you would rather use those instead of a relay.
Thanks WKirby - I have ordered a seperate port BMS that doesnt switch off the charging current, Ill let you know how I get on.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
7 People are following this question.
Internal vs External BMS pros and cons
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Are 50vdc solar panels wasted on a 12vdc system?
Lithium Battery miniBMS / VE Bus BMS / BMS 12/200 - Low temperature protection available?
Large difference between solar blanket voltage output and Victron dashboard
