PVTex avatar image
PVTex asked
Help needed: Power Meter lib for Modbus-based meters WS100
i have created the new device WS100
ws100.py
import logging
import device
import probe
from register import *
log = logging.getLogger()
class ws100_Meter(device.EnergyMeter):
    productid = 0xb017
    productname = 'WS100 Meter'
    min_timeout = 0.5
    def __init__(self, *args):
        super(ws100_Meter, self).__init__(*args)
        self.info_regs = [
            Reg_text(0x1000, 4,'/Serial'),
            Reg_u16b(0x1004, '/FirmwareVersion'),
    def device_init(self):
        self.data_regs = [
            Reg_u32b(0x0104, '/Ac/Power',          100, '%.1f W'),
            Reg_u16b(0x010a, '/Ac/Frequency',      100, '%.1f Hz'),
            Reg_u32b(0x010e, '/Ac/Energy/Forward', 100, '%.1f kWh'),
            Reg_u32b(0x0118, '/Ac/Energy/Reverse', 100, '%.1f kWh'),
            # We always have L1 voltage and current
            Reg_u32b(0x0100, '/Ac/L1/Voltage',      10, '%.1f V'),
            Reg_u32b(0x0102, '/Ac/L1/Current',     100, '%.1f A'),
            Reg_u32b(0x0104, '/Ac/L1/Power',          100, '%.1f W'),
            Reg_u32b(0x010e, '/Ac/L1/Energy/Forward', 100, '%.1f kWh'),
            Reg_u32b(0x0118, '/Ac/L1/Energy/Reverse', 100, '%.1f kWh'),
    def get_ident(self):
        return 'ws100_%s' % self.info['/Serial']
models = {
    0x07000015 : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_21',
        'handler':  ws100_Meter,
    0x006970016 : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_22',
    0x05920017 : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_23',
    0x11720018 : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_24',
    0x11710019 : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_25',
    0x1179001a : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_26',
    0x0460001f : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_31',
    0x06990020 : { # WS100 (0x0091 2224 0700 0015)
        'model':    'WS100_32',
probe.add_handler(probe.ModelRegister(Reg_u32b(0x1002), models,
                                      methods=['rtu','tcp'],
                                      units=[21, 22, 23, 24, 25, 26, 31, 32]))
the new device is found:
@4000000064d35da3374642cc INFO     Found WS100_22 at tcp:192.168.88.186:502:22
@4000000064d35da51a0863fc INFO     Found WS100_21 at tcp:192.168.88.186:502:21
@4000000064d35da60ceac14c INFO     Found WS100_31 at tcp:192.168.88.186:502:31
@4000000064d35da702f3ddf4 INFO     Found WS100_32 at tcp:192.168.88.186:502:32
but it is not displayed in the device list.
what have i done wrong?
Energy MeterModbus TCPpower meter
Energy Meter Selection Guide
Modbus TCP Basics
