bonsys avatar image
bonsys asked
Is negative sign a must when setting temperature compensation value?
Battery spec calls for +/- mV when setting temperature comparisons. Which makes sense as charge voltage is increased or decreased based on temperature. But Victron mppt only allows "-" negative sign or no sign at all. Negative sign is used by default. Can Victron support clarify the importance of the negative or positive sign in this case? How firmware handles the mV offset value if the sign is not set?
Example: -18mV vs 18mV
No sign and positive are the same thing. There is no other sign.
Kevin Windrem avatar image Kevin Windrem seb71 commented ·
It is generally understood that a number without a sign is a positive value.
However, a plus sign is sometimes included when it is important that the value is understood to be positive. I think that is the point bonsys was making.
wkirby avatar image
wkirby answered ·
The negative sign is important because you want the battery Voltage to decrease with rising battery temperature in order to mitigate thermal runaway.
If a positive (unsigned) number were used then that would induce thermal runaway by increasing the battery Voltage the hotter it gets which in turn makes it hotter and so forth.
4 comments
And because ... mathematics....
bonsys avatar image bonsys commented ·
but how about colder climates? What is the logic with temperature compensation when charging conditions are below 25C?
kevgermany avatar image kevgermany ♦♦ bonsys commented ·
It increases the charge voltages
bonsys avatar image bonsys kevgermany ♦♦ commented ·
yes, I would expect that too - thank you! But for some reason I am not observing it at all. Posted this as a new question: https://community.victronenergy.com/questions/232571/should-multiplus-temp-compensate-in-absorption-mod.html
