andersskogen avatar image
andersskogen asked
Time off variable in API is wrong for one site
Hi!
We have 80-odd systems in our VRM user, and use the API to collect and report monthly downtime for these. We use the https://vrmapi.victronenergy.com/v2/installations/{id}/stats endpoint with attributeCodes[]=To and a few other variables to get 15-min data.
One of our systems is frequently down at night due to missing power on AC in. In July it was down 69 hours by looking at the ve.bus state over the period.
When I check the downtime at this site from the stats API, "To" (time off) is (always) null and Ti (time inverting) is 900 (=15 min x 60 seconds), indicating the system was always inverting. The Ve.bus state is correctly reported as "off" for the same time period, and it is visibly down in the VRM gui.
For the remaining 80-odd sites, we can correctly sum over the "To" parameter to find downtime. We have five systems with same config as this, but with correct reporting.
Why does the To API data not correctly show downtime for this one system?
apishutdown
markbailey avatar image
markbailey answered ·
Hello, Schnucks
The API data for one of your systems inaccurately reports downtime as the To attribute is consistently null and the Ti attribute indicates constant inversion. This contrasts with the correct reporting in the VRM GUI and other similar systems. The cause of this discrepancy requires investigation and resolution.
