nesswill avatar image
nesswill asked
SUGGESTION - VRM Dashboard AC Load add amps + volts
Hi Victron guys and girls can i ask/suggest this please.
I guess this has been asked before but could not find an answer... (sorry if this has been discussed and rejected or noted to be done at some point)
For me being off grid i would find it useful to have amps + volts under the watts in the AC Loads window. (Like in the PV Charger Window)
Small ask?
Thanks
VRM
craigtong avatar image
craigtong answered ·
I'd like to +1 this suggestion.
What I am interested in is related and could be rolled out in the same change is to show volts and frequency on the AC Input even if AC input is ignored. That way you can readily see the current status of the grid or shore power even if not using it.
