harrymike2 avatar image
harrymike2 asked
Victron Replacement for AMP-L-START 15 Amp Starting Battery Maintainer
Hi Victron Energy,
I am trying to find a suitable replacement for a AMP-L-START??? see end for AMP-L-Start description.
I have a 2020 Winnebago Navion with 4X 100W Solar Panels, 2X 100aH Battle Born Lithium's (in parallel) and ZAMP Solar Controller, Xantrex Freedom XC 2000W converter and more importantly a Alternator Charging Solenoid (Charge Mate Pro Master Volt) installed by Winnebago. Therefore, I only care about one way trickle charging from the 2X 100aH Battle Born Lithium's to the Mercedes Chassis battery during 2-week to 6-week storage intervals.
The tech at Battle Born suggested the Orion TR Smart 12/12 18Amp DC-to-DC, he said he can help with the settings. What is the best solution if I want to purchase a Victron Product?
AMP-L-START™ is designed to keep your engine starting battery(s) fully charged during long periods of storage or inactivity. Connected
between the house and starting batteries, it diverts up to 15 amps of charging current from your existing house battery charger, sending it to the starting battery(s)
instead.
Thanks - Mike
battery charging
kevgermany avatar image
kevgermany answered ·
Orion chargers will do the job. 18A is probably overkill, you're only going to need a few amps. Ballpark is roughly 4% of your starter battery size. So 4A for a 100Ah battery.
You can also use the Orion power supply range, set the output voltage to the float or storage voltage of the starter battery.
harrymike2 answered ·
Thanks kevgermany, I think the 18A was the smallest DC-to-DC Victron has? Wonder if there are setting to current limit the output Amps?
Thanks again - Mike
No current control at all, it is voltage driven, up to its max output.
