Hi folks,
My first post having bought quite a bit of Victron stuff in the past. It's all been great so I haven't had a need to explore forums.
However, I have recently upgraded my new campervan to a lithium battery setup, with the Orion 12/30 DC charger. The existing setup is this Power Management System, that routes the power from the battery to the various systems, whilst also providing fuse and rcd breakers.
The system has a 240v input from shore power, that can run wired 240v sockets inside the camper, but also charge the battery if the charger switch is enabled.
My question is, can I use this with a lithium battery? I know the Orion is good for lithium, which is great, but I'm unsure about this. Also, I've installed a Phoenix inverter which I have wired to a separate internal 240v socket.
Would I have to change to a Multiplus and then have a separate control panel instead? Thoughts and opinions very welcome. Thanks.
![bonuspms3campercharger-3589181249.jpg](/storage/attachments/58723-bonuspms3campercharger-3589181249.jpg)
