janvi avatar image
janvi asked
Number of connections for Cerbo GX remote console
After some suspicious unreliabilities what shows a suddenly unexpected disconnect of the Cerbo GX remote console over LAN I digged into this problem. Obviosly, the http server allows only one login to the remote console. If there is another login from another machine, the previous connection is disconnected. Where and how to set the number of possible users to the Cerbo http server ? There is no flat internet available. Cerbo memory and computing power should be sufficient for anything like 3-5 local users. I plan to display the information graphics at serveral locations permanently to gain information about the available energy and how to behave in the situations.
cerbo gxremote console
nickdb avatar image
nickdb answered ·
The limit is not related to http. It is the architecture of how the console is rendered. There is no way around it.
That should be changing in the future with the next gen console, if memory serves me correctly.
For now it is something you have to live with.
Basic ESS settings can be changed via VRM outside of the console and that is multi-user.
Kevin Windrem avatar image
Kevin Windrem answered ·
As an alternate, you can use the "marine app": venus.local/app. It's not the full GUI but you can run multiple connections simultaneously.
janvi avatar image
janvi answered ·
For the moment I use the Teamviewer remote connectivity tool to duplicate a master screen to several other displays. Finally I have to write probably something by myself using MQTT by FHEM or OpenHAB what also customizes the image to my other needs
