P.H.J. Sibbing avatar image
P.H.J. Sibbing asked
VRM widget tags description
Today the decriptions of the Widget on the dashboard have been supplemented with the text "Recorded".
Is this a way to avoid some kind of liabilty for the figures shown ?
The Dutch translation is also wrong "opgenomen" should be "geregistreerd" because "Opgenomen" can only be valid for the amount taken from the grid.
The only lliable figures are the figures shown on the physical grid meter from your power supplier or grid operator with which Victron does not have an connection.
All other data is informative recorded or non recorded. these addition are BS.
Why add "recorded" All data you see in the VRM is recorded some where otherwise it would be possible to show it.
VRM
