mivester avatar image
mivester asked
MPPT RS triggering short on Lithium BMS
I am hooking up a SmartSolar MPPT RS 450/100 to a 48VDC string of lithium batteries. The MPPT is hooked up to a Lynx bus through a breaker, with the batteries hooked to the Lynx through a disconnect switch. The batteries have switches directly on them as well.
I have the batteries turned on and the Bus is sitting at 48VDC. Then I close the breaker to the MPPT. Immediately the battery goes into alarm showing discharge short circuit detected. I can then reset the battery and clear the alarm. At this point it is fine and everything seems to work correctly.
MPPT SmartSolarmppt rs
Alexandra avatar image
Alexandra answered ·
@Mivester
What exactly is the error that is logged?
Is it error #27?
mivester answered ·
I do not have Victron batteries on this setup, it is a string of PSI 100AH batteries. All that I have is the alarm that comes up through that.
The MPPT is not showing any errors that I can see. It is being monitored through a Cerbo and I did not see any alarm logs.
I am wondering if there could be a huge initial draw to charge capacitors? Just rather confused otherwise.
