matmah avatar image
matmah asked
How to I stop my Lithium battery going into storage mode with a Blue Smart IP65 Charger?
Every time I charge my battery (Renogy 50ah) it bulk charges, goes into absorption mode then into storage.
My issue is that all I want to do is charge the battery up to it's maximum amount then disconnect it. I do not want it to go into storage mode and reduce the amount of energy it is storing.
Is there a setting i can change to stop this from happening?
battery charging
klim8skeptic avatar image
klim8skeptic answered ·
@matmah dont panic!
Storage voltage for Li batteries is the same as float voltage!! 13.5v.ip65-storage.png
Perfectly safe voltage for Li batteries being held at near full state of charge. (probably 98% after a little voltage drop from the bulk/absorption voltage of 14.2v)
You have programmed your IP65 to charge Li batteries?????
