nbo avatar image
nbo asked
Cooling ventilation BMS CL 12/100 versus cooling Orion Smart TR
First I had the idea to install a Victron Superpack. But the space for the Orion TR to charge it by the alternator is quit limited. And the Orion requires 10 cm min for cooling above and below.
So now the idea is to use the BMS CL 12/100 instead. which I can mount on an other location. As I have the idea the cooling vent requirements are not mentioned in the manual and there fore not that critical as I assume.
Any thought if this assumption is correct. Price of whole installation is higher but if this solves the issues it is fine with me.
BMSorion-tr smart
mvas avatar image
mvas answered ·
Operating Temperature Range -40°C to +60°C
