edward-kerr avatar image
edward-kerr asked
Reboot and firmware update resets the Relay states(s)
Hi
Could I ask that when you provide an update to the Venus Firmware that you ensure the original positions of the relays are retained. Every update sent currently defaults the relays to the off position and this causes problems when the user is not made aware of the update and has the expectation that following any auto update the settings would all remain. As they were prior to the update.
Venus GX - VGX
Hi @Edward Kerr, I checked, and indeed the state is not maintained.
The state, when using the relay in the 'manual' function, is not only reset during a firmware update, during all reboots.
At boot, the relays as reset to off. There is no functionality implemented right now to store the state.
I've added it to the todo list.
