xavifm avatar image
xavifm asked
Feature Request for VRM function with Phoenix inverter.
It is known throughout the Victron community that AC load readings on Phoenix inverters are inaccurate and calculated ....there is no internal shunt or meter.
It is a shame that equipment like this ,cannot see real and reliable readings on the dashboard.
I would like the VRM portal programmers will enable to show the ET112 meter reading on the dashboard whenever the victron inverter is connected.
I mean that I could select which reading we can see on the dashboard, the calculated ac load of the victron inverter or the readings of the et112, as long as the victron inverter is connected to make sure that an original Victron inverter is connected in the system.
Please bring the posibility to see real and reliable power readings on the dashoard. Thanksss
VRM
